15 years agoDedicated Logic Register problem
I'm working with Cyclone 3, EP3C10F256I7. When I'm doing full compilation the flow summery let me know that the "Total Combination Function" is 1% and the "Dedicated Logic Register" is 1% also. When I'm trying to do full compilation with Serial Flash Loader (from Mega wizard), the "Dedicated Logic Register" increase to ~125% and the compilation is unsuccessful ("Can't fit design in device"). I 99% sure that the problem is not my code or hardware problem. I do think it connected to the process I'm loading the IP (in the "files" I'll see the name. VHD and .CMP) or some other setting (maybe Pin Assignment (witch I didn't do)...). If you'll need more information about the problem I would love to give you a call if you'll send me your full phone number and the time that would be best for you. Thanks...
