9 years agoDebugging the Hardware fault
I have Cyclone III fpga board with Ethernet interface and JTAG connector for Active Serial Programming through USB Blaster.
If I plug in the Ethernet connector - the PC is not recognizing the hardware - i too can make the Ethernet connector light is not coming up. When i tried to load the boot-loader through USB Blaster - its not successful. Under this situation i am not able to guess what went wrong - is it the fpga or eeprom - Could any one can tell me other way to understand what i should look into to correctly figure out the issue -Suzane12 Replies
If that LED is blinking then the FPGA must be configuring from the serial PROM/EEPROM U1. So, no. I don't think you have a problem with your EEPROM.
The fact you can't talk to the FPGA via JTAG is worrying. I've never known a 'working' board (that boots from it's EEPROM) not respond via JTAG. --- Quote Start --- The board is not recognizing the ethernet port also when connected to a pc also --- Quote End --- What makes you think this? No LINK? Is the Phy (U13) getting the right clocks? Is it out of reset (RESET_N)? Cheers, Alex - Altera_Forum
Hi Alex,
I did not check the clocks. I am trying to go by some common sense - what i am trying to mean - what could be common thing involved which has disrupted the communication between JTAG to FPGA and PHY to FPGA ? AT LEAST I AM NOT ABLE TO FIGURE OUT Regards Suzane
