9 years agoDebugging the Hardware fault
I have Cyclone III fpga board with Ethernet interface and JTAG connector for Active Serial Programming through USB Blaster. If I plug in the Ethernet connector - the PC is not recognizing the ...
9 years agoIf that LED is blinking then the FPGA must be configuring from the serial PROM/EEPROM U1. So, no. I don't think you have a problem with your EEPROM.
The fact you can't talk to the FPGA via JTAG is worrying. I've never known a 'working' board (that boots from it's EEPROM) not respond via JTAG. --- Quote Start --- The board is not recognizing the ethernet port also when connected to a pc also --- Quote End --- What makes you think this? No LINK? Is the Phy (U13) getting the right clocks? Is it out of reset (RESET_N)? Cheers, Alex
