17 years ago
DE2-70 RS232 and VGA Question
I'm currently working on my Senior Project and I'm having many problems :mad: ... For starters I need to interface a CDMA Modem via Serial (RS232) and have the DE2-70 throw out AT commands that the Cell Modem can understand and send out the SMS message... I verified all the commands with HyperTerminal and everything works great... I just need to come up with some VHDL code that can talk to the RS232 port and send AT commands to the Modem... I am a complete n00b with VHDL, but I am familiar with Quartus software... If anyone can help get me started on some VHDL code for the RS232 port I would be most grateful... Later down the line I would like to display just the text comming off of the RS232 port to a VGA monitor... Again, not a clue where to start... I did some searching on this fourm, but haven't found an exact answer to my problem... Thanks in advance....
    Hello everyone!
    In Nios II, when I use getchar() function, I encounter with the problem :"undefined reference to getc".What's the problem? What should I do? I will appreciate very much with your help. Thanks!
    Are you using the small c library? In that case you could be limited in the functions you can call.
