10 years agoDE0-Nano-SoC: How HPS(ARM) recognizes f2h_irq0 or f2h_irq1 interrupts from FPGA
I designed a block in Verilog. When data processing is finished, this FPGA block sends an interrupt signal to HPS using one of dedicated interrupt line: f2h_irq0 or f2h_irq1. The question is how HP...
9 years agoCan you put that project back up? It's exactly what I'm looking for. Thanks in advance.
--- Quote Start --- -Hei sebar, download your ds5 example from here, and follow the instructions, place the folder into your DS5 workspace, open ds5 and import the project. - Watch the project configurations, makefile etc ... - Make some stupid change into the main.c such as adding a comment and then build all, you must not see any error, warning or file missing. - If any error occurs you can ask to me for see what it happens. https://www.sendspace.com/file/okshc0 --- Quote End ---
