10 years agoDE0-Nano-SoC: How HPS(ARM) recognizes f2h_irq0 or f2h_irq1 interrupts from FPGA
I designed a block in Verilog. When data processing is finished, this FPGA block sends an interrupt signal to HPS using one of dedicated interrupt line: f2h_irq0 or f2h_irq1. The question is how HP...
10 years agoC:\altera\15.1\embedded\embeddedsw\socfpga\prebuilt_images\kernel_headers\include\linux
All these files and all you need is inside the EDS suite. The nano soc manual shows you how cross compile with the shell but i work and program in ds5 eclipse because you can acces the linux terminal, explore the filesystem and debug the programs This pic illustrates how i work. http://s28.postimg.org/g9ussmjml/2016_01_17_10h40_29.png I can guide you to configure the workspace if you want!!
