14 years agoDE0-Nano Control Panel connect problem
this is my first time use Altera fpga board, i copy the "DE0_Nano_ControlPanel" folder and try to run the application, it shows connection problem due to two missing file "jtag_client.dll" and "dinkum_alt.all", after copy two files from installation folder /bin directory, (why they don't include these two files in the folder?, user manual says just copy the folder and run the applicaiton.......) it shows "quartus_pgm download fail(0 sec), if click "ok", it shows "download SOPC file (DE0_Nano_ControlPanel.sof) fail! DE0_Nano_ControlPanel.sof is existing in the folder, so any idea what is going on there? Thanks, Bryce16 Replies
Hi guys, I'm have the same problem.
I run Win7 (64bits), and I have followed guiding of miyoung1984. But I cann't solve this problem. Pls help me. Thanks so much! - Altera_Forum
Thanks! This helped. What a pain. I finally got my first FPGA project to load on the Deo-Nano! Others were saying it couldn't be done on windows 7 easily but this was easy.
Bryce,
I had a similar problem to yours. First, I downloaded the newest version of the Control Panel from Terasic. This only marginally helped in that it changed the error message slightly. What my problem was, was that the drivers weren't loaded for the DE0-Nano. It showed up in the device manager as a USB-Blaster. I updated the drivers through the update client in the device manager program by navigating to C:\altera\10.1\quartus\drivers and letting the computer install what it felt was appropriate. I am running windows 7 x64 professional. Hope that helps. Michael- MGree42
This worked for me on the DE10-Lite board as well.
When I ran this command:
.\bin64\quartus_pgm.exe -m jtag -c USB-Blaster[USB-0] -o "p;C:\Users\Michael Green\OneDrive\Documents\DE10-Lite-v.2.0.3_SystemCD\Tools\ControlPanel\DE10_Lite_ControlPanel.sof"I got this error:
Error (213013): Programming hardware cable not detectedSo with the board connected, I just reran this:
C:\IntelFPGA_lite\19.1\quartus\drivers\DPInstI then relaunched the control panel and was able to connect to the board
- ahmed3
walahy el 3azeem kalam 100%
