14 years agoDE0-Nano Control Panel connect problem
Hi, this is my first time use Altera fpga board, i copy the "DE0_Nano_ControlPanel" folder and try to run the application, it shows connection problem due to two missing file "jtag_client.dll" ...
14 years agoBryce,
I had a similar problem to yours. First, I downloaded the newest version of the Control Panel from Terasic. This only marginally helped in that it changed the error message slightly. What my problem was, was that the drivers weren't loaded for the DE0-Nano. It showed up in the device manager as a USB-Blaster. I updated the drivers through the update client in the device manager program by navigating to C:\altera\10.1\quartus\drivers and letting the computer install what it felt was appropriate. I am running windows 7 x64 professional. Hope that helps. Michael- MGree426 years ago
This worked for me on the DE10-Lite board as well.
When I ran this command:
.\bin64\quartus_pgm.exe -m jtag -c USB-Blaster[USB-0] -o "p;C:\Users\Michael Green\OneDrive\Documents\DE10-Lite-v.2.0.3_SystemCD\Tools\ControlPanel\DE10_Lite_ControlPanel.sof"I got this error:
Error (213013): Programming hardware cable not detectedSo with the board connected, I just reran this:
C:\IntelFPGA_lite\19.1\quartus\drivers\DPInstI then relaunched the control panel and was able to connect to the board
