DDR3 timing errors on Cyclone V
Closing timing on a design using the 5CGTFD9E5F35C7, getting a few (17) setup failures on a DDR3 controller core; launch and latch clock are different, but both are part of DDR3 core. From: and to: nodes are also all internal to core. An example:
slack: -3.404
from node: ddr3_v20:ddr3_v20_inst|ddr3_v20_0002:ddr3_v20_inst|ddr3_v20_s0:s0|altera_mem_if_sequencer_cpu_cv_synth_cpu_inst:cpu_inst|W_alu_result[15]
to node:
ddr3_v20:ddr3_v20_inst|ddr3_v20_0002:ddr3_v20_inst|ddr3_v20_s0:s0|sequencer_scc_mgr:sequencer_scc_mgr_inst|scc_parallel
launch clock:
ddr3_v20_inst|ddr3_v20_inst|pll0|pll6~PLL_OUTPUT_COUNTER|divclk
latch clock:
ddr3_v20_inst|ddr3_v20_inst|pll0|pll7~PLL_OUTPUT_COUNTER|divclk
relationship: 0.000
clock skew: -0.599
data delay: 2.735
Note that launch and latch edges are coincident (doesn't seem quite fair does it?). The clock frequencies seem to be quite low (<= 50 MHz?). Closure recommendations provided by Timing Analyzer all seem to ask for changes to the core design (move nodes - not sure exactly what that means, duplicate nodes, ensure launch and latch frequencies are exact multiples, reduce levels of logic).
I would think that the SDC files created by Platform Designer would have constrained the core sufficiently.
Suggestions?
- AdzimZM_Altera
Hi Seadog,
Thanks for using Intel Community.
I'm Adzim, AE that will assist you in this thread.
I really appreciate if you can share the design with me for replication purpose.
Adzim
- Seadog
Hi Adzim,
I can not share the design, it is ITAR restricted. I have attached a spreadsheet with the details on the errors. I can summarize the problem as well:
- the 'From Nodes' and and 'To Node' (all errors are associated with the same 'To Node'), and the Launch and Latch Clocks are all internal to the DDR3 core
- the Launch and Latch clock edges in question are coincident, thus the timing relationship (delay/skew budget) is 0.0 ns
- there are numerous other paths using the same launch and latch clocks which do not have timing errors; the difference is that in the error cases, the latch clock is using the falling edge, whereas in the non-error cases, the latch clock uses the rising edge
