Seadog
4 years agoDDR3 timing errors on Cyclone V
Closing timing on a design using the 5CGTFD9E5F35C7, getting a few (17) setup failures on a DDR3 controller core; launch and latch clock are different, but both are part of DDR3 core. From: and to: ...
AdzimZM_Altera
4 years agoHi Seadog,
Thanks for using Intel Community.
I'm Adzim, AE that will assist you in this thread.
I really appreciate if you can share the design with me for replication purpose.
Adzim
Seadog
4 years agoHi Adzim,
I can not share the design, it is ITAR restricted. I have attached a spreadsheet with the details on the errors. I can summarize the problem as well:
- the 'From Nodes' and and 'To Node' (all errors are associated with the same 'To Node'), and the Launch and Latch Clocks are all internal to the DDR3 core
- the Launch and Latch clock edges in question are coincident, thus the timing relationship (delay/skew budget) is 0.0 ns
- there are numerous other paths using the same launch and latch clocks which do not have timing errors; the difference is that in the error cases, the latch clock is using the falling edge, whereas in the non-error cases, the latch clock uses the rising edge
