DDR3 SDRAM Examle Design state machine
module Avalon_bus_RW_Test (
iCLK,
iRST_n,
iBUTTON,
local_init_done,
avl_waitrequest_n,
avl_address,
avl_readdatavalid,
avl_readdata,
avl_writedata,
avl_read,
avl_write,
avl_burstbegin,
drv_status_pass,
drv_status_fail,
drv_status_test_complete,
c_state,
y0, y1, y2,z,y
parameter ADDR_W = 26;
parameter DATA_W = 128;
input iCLK;
input iRST_n;
input iBUTTON;
input local_init_done;
input avl_waitrequest_n; // avl.waitrequest_n
output [ADDR_W-1:0] avl_address; // .address
input avl_readdatavalid; // .readdatavalid
input [DATA_W-1:0] avl_readdata; // .readdata
output [DATA_W-1:0] avl_writedata; // .writedata
output avl_read; // .read
output avl_write; // .write
output drv_status_pass;
output drv_status_fail;
output drv_status_test_complete;
output avl_burstbegin;
output [3:0]c_state;
output [63:0] y0, y1, y2;
output [7:0] z;
output [127:0] y;
// Signal declarations
reg [63:0] clk_cnt, cal_data;
reg [1:0] pre_button;
reg trigger;
reg [DATA_W-1:0] data_reg;
wire [63:0] y0, y1, y2;
wire [7:0] z;
wire [DATA_W-1:0] y;
reg [3:0] c_state;
reg avl_write, avl_read;
reg [ADDR_W-1:0] avl_address;
reg [DATA_W-1:0] avl_writedata;
reg [4:0] write_count;
wire max_avl_address;
wire same;
// Structural coding
assign avl_burstbegin = avl_write || avl_read;
assign y0 = cal_data + {44'b0, avl_address};
assign y1 = {y0[31:0], y0[63:32]} ^ cal_data;
assign y2 = y1 + cal_data;
assign z = y1[7:0] + y2[7:0];
assign y = {y2[61:5],z,y2}; //128 bits 32bits DDR3 width,128 bits avalon data; data not allign to 32 bits
assign max_avl_address = &avl_address;
assign same = data_reg == avl_writedata;
always@(posedge iCLK)
if (!iRST_n)
clk_cnt <= 64'b0;
else
clk_cnt <= clk_cnt + 64'b1;
begin
if (!iRST_n)
begin
pre_button <= 2'b11;
trigger <= 1'b0;
write_count <= 5'b0;
c_state <= 4'b0;
avl_write <= 1'b0;
avl_read <= 1'b0;
end
else
begin
pre_button <= {pre_button[0], iBUTTON}; //spam
trigger <= !pre_button[0] && pre_button[1];//spam
case (c_state)
0 : begin //idle
avl_address <= {ADDR_W{1'b0}};
if (local_init_done && iBUTTON)
begin
cal_data <= clk_cnt;
c_state <= 1;
end
end
1 : begin //write
avl_writedata <= y; //sdc set multi-cycle 3
if (write_count[3])
begin
avl_write <= 1'b1;//output of this state and
c_state <= 2;// and at the same time change state to 2.
end
else
write_count <= write_count + 1'b1;
end
2 : begin //finish write one data
if (avl_waitrequest_n) // if this happens then
begin
avl_write <= 1'b0; // and output of this state is this
c_state <= 3; //next state is this
end
end
3 : begin
if (max_avl_address) //finish write all(burst)
begin
c_state <= 10;
end
else //write the next data
begin
avl_address <= avl_address + 1'b1;
c_state <= 1;
end
end
10 : c_state <= 11;
11 : c_state <= 4;
4 : begin //read
avl_read <= 1;
if (!write_count[3])
c_state <= 5;
end
5 : begin //latch read data
avl_read <= 0;
write_count <= write_count + 5'b1;
if (avl_readdatavalid)
begin
data_reg <= avl_readdata;
c_state <= 6;
end
end
6 : begin //finish compare one data
if (write_count[3])
begin
if (same)
c_state <= 7;
else
c_state <= 8;
end
else
end
7 : begin
if (max_avl_address) //finish compare all
begin
c_state <= 9;
end
else //compare the next data
begin
c_state <= 4;
end
end
8 : c_state <= 8;
9 : c_state <= 9;
default : c_state <= 0;
endcase
end
end
// test result
assign drv_status_pass = (c_state == 9) ? 1 : 0;
assign drv_status_fail = (c_state == 8) ? 1 : 0;
assign drv_status_test_complete = drv_status_pass || drv_status_fail;
endmoduleBelow is the RTL code of state machine for DDR3 SDRAM writing or reading module. In example design. I just wana know why at Avalon wait request(n) , the avalone write or avalone read signla is put to 0? avalone waitreq(n) is active low signal so avalone write should be 1 when it goes low. anyone know the reason please? It is in state 2 and state 4 and 5
- NurAida_A_Intel
Dear @matif ,
Is this coding (memory test module) obtained from Terasic board (please correct me if I'm wrong) ? Because I am not aware of this test module so far.
I would like to help but unfortunately I am not coding expert here. If this is the test module from Terasic, I suggest you to contact the Terasic vendor and address the query.
Please let me know your feedback or anything further I could help you. 😊
Aida
- NurAida_A_Intel
Hi @matif ,
I am sorry for the delay in response due to current workload.
Let me clarify on DDR3 controller signal as below and hope it help for your understanding.
- When "local_init_done” goes high, this indicate DDR3 calibration is completed and DDR3 controller is ready to accept user Avalon MM command. (user can send avalon command but controller won't process it yet)
- User command will only be process once DDR3 avalon slave "avl_ready" goes high or its respective avalon master "wait_request" (this is normal wait_request signal without 'n') goes low .
- So, yes you're right, the waitreq(n) is active low signal. Means that signal will be performing its function when its logic level is 0. So, there will be no data transaction (read/write , logic level is 0) during this period until the avl_ready goes high.
Hope this clear.
Aida
- matif
Dear Aida,
Thank you so much for your reply. Is there any documentation of the above code? There are still some points that I need to understand. For example, in state 1 why is if (writecount[3]) is being used. It will be great if you can share some documentation of the above code.
