matif
6 years agoDDR3 SDRAM Examle Design state machine
module Avalon_bus_RW_Test (
iCLK,
iRST_n,
iBUTTON,
local_init_done,
avl_waitrequest_n,
avl_address,
avl_readdatavalid,
avl...
NurAida_A_Intel
6 years agoHi @matif ,
I am sorry for the delay in response due to current workload.
Let me clarify on DDR3 controller signal as below and hope it help for your understanding.
- When "local_init_done” goes high, this indicate DDR3 calibration is completed and DDR3 controller is ready to accept user Avalon MM command. (user can send avalon command but controller won't process it yet)
- User command will only be process once DDR3 avalon slave "avl_ready" goes high or its respective avalon master "wait_request" (this is normal wait_request signal without 'n') goes low .
- So, yes you're right, the waitreq(n) is active low signal. Means that signal will be performing its function when its logic level is 0. So, there will be no data transaction (read/write , logic level is 0) during this period until the avl_ready goes high.
Hope this clear.
Aida
matif
6 years agoDear Aida,
Thank you so much for your reply. Is there any documentation of the above code? There are still some points that I need to understand. For example, in state 1 why is if (writecount[3]) is being used. It will be great if you can share some documentation of the above code.
