16 years agoDDR2-SDRAM High performance controller
Hi All, I am currently using the DDR2-SDRAM High performance controller on Quartus II 8.0. I assume that the controller had been successfully generated. but i can not effectively test the the s...
16 years ago --- Quote Start --- High Performance is a setting (radio button) selection on DDR2 MegaVizard environment that you set and it makes the DDR2 core a high performance core. You don't manually change the core to make the core high performance. --- Quote End --- Oh I see. Thanks!
