16 years agoDDR2-SDRAM High performance controller
Hi All, I am currently using the DDR2-SDRAM High performance controller on Quartus II 8.0. I assume that the controller had been successfully generated. but i can not effectively test the the s...
16 years ago --- Quote Start --- Hey, sorry to intrude here, but when I read 'high performance' SDRAM controller, I just wanted to know what design criteria(s) makes the performance impact?? Thank you! --- Quote End --- High Performance is a setting (radio button) selection on DDR2 MegaVizard environment that you set and it makes the DDR2 core a high performance core. You don't manually change the core to make the core high performance.
