14 years agoDDR2 pin assignment
This is a very long shot, probably nobody will answer this, but here I go just in case. In Quartus II 11.1, for an EP4CGX50CF23C7 (F484 package, speed grade 7), I instantiated an altmemphy int...
14 years agoThe Cyclone IV handbook has a section on External Memory Interfaces that I believe is pretty clear on having specific DQ/DQS groups. I don't say that to be mean, but am wondering if it's not clear enough?
I am also a huge advocate of building a framework for the design before building the board. I know that's difficult to do, but I've seen more than enough cases where it costs more time in the end. Again, I don't mean to be mean. Finally, please file an SR to see if there is any way to disable this check. Since this is probably just a test board now, that might free up any restrictions. Note that Stratix devices have dedicated paths and logic in silicon that absolutely require the pairing of a DQ with its DQS, but looking at the CIV datasheet, I don't see anything similar. It may be this is more of a software check, in which case maybe you can get a workaround. A longshot, but would help if it works. Good luck.
