16 years agoDDR2 DQSn Pin Question
Hi, All I am using Cyclone III and DDR2 as memory, I found there is no DQSn Pin in CycloneIII device. So how to connect DQSn pin in DDR2 memory device. Connect to Vtt=0.9V or GND, or somewhere...
16 years agoUnless you make a psudo-diff pin set by taknig the signal and it's inversion - placing them next to each other and adding proper termination on the board. THen it will be a mtter of the speed you are looking to obtain - best to do some PCB simulation with something like HyperLinx to make sure it all works.
Regards, Avatar
