16 years agoDDR2 DQSn Pin Question
Hi, All I am using Cyclone III and DDR2 as memory, I found there is no DQSn Pin in CycloneIII device. So how to connect DQSn pin in DDR2 memory device. Connect to Vtt=0.9V or GND, or somewhere...
16 years ago --- Quote Start --- Hi, it depends. In DDR2, the DQS signal may either be single ended or differential. Take a look in your DDR2 device's datasheet about this. If you are using a diferential DQS, then you need to set the DQS signal to the a differential SSTL I/O standard. The DQS_n signal will then be automatically assigned to the proper pin. --- Quote End --- But I can not find any DQSn pin in the Cyclone III device, is that means CIII device can not support differential DQS mode? Thanks
