16 years agoDDR Output Constraining - "too positive" slack
Hi, I hope someone knows the solution to the problem that kept me really busy lately :( I have to connect to an RGMII PHY that has the following parameters: tCLK = 8 (ns) TskewR (Da...
16 years ago --- Quote Start --- I gave up with RGMII, most likely will go with GMII PHYs. --- Quote End --- Did you consider adding 1 pipeline cycle and swapping the data for high and low clock edges? I don't recall all the (r)GMII details, but IIRC you can insert an extra cycle on the transmitter pipeline. The idea is to transmit on the opposite edge of the clock. This way you wouldn't need to delay the clock, because data would naturally be delayed with respect to the clock.
