remov_b4_flight
1 year agoDDR IP on stratix3
Hi, my project uses stratx3 insides ddr3 controller w/UniPHY, on Fitter lots of 174068 and 174058 errors are appared. Error (174052): I/O "mem_dq[0]" has dynamic termination control connected, but...
- 1 year ago
IIRC, you had to run a Tcl script to create all the I/O assignments needed to work with the IP. Did you run that script?
sstrell
1 year agoIIRC, you had to run a Tcl script to create all the I/O assignments needed to work with the IP. Did you run that script?
