16 years agoDDIO Input nodes could not be constrained by the Fitter to improve DDIO timing
Hello, I have a design with a 16-bit wide DDR2 memory and a 10 bit DDR interface to another peripheral, that makes a total of 26 DDR Input pins. I get this Info+Warning during the fitting...
16 years agoThis is typically the best approach even with the high-end FPGA families. DDR interfaces have special pin requirements.
This is how I usually approach it: 1 - Constrain the interface to an edge of the chip. 2 - Let the Fitter decide which pins to use (because it knows the rules). 3 - back-annotate 4 - Make tweaks as needed 5 - Re-compile to ensure the fitter agrees with your tweaks. 6 - repeat steps 4&5 as needed.
