15 years agoDCFIFO - incorrect functionality of a ModelSim timing simulation
Hey guys,
A brief background:My VHDL design (for Stratix III) has input data arriving at 20MHz. The data is read at a rate of 100Mhz. The reading and writing operations aren't necessarily simultaneous. I have prepared a dedicated FIFO block, based on the DCFIFO megafunction, to handle this input interface. The relevant DCFIFO settings I have chosen: overflow_checking => "ON" underflow_checking => "ON" rdsync_delaypipe => 3 wrsync_delaypipe => 3 use_eab => "ON" write_aclr_synch => "ON" The problem:The block works smoothly in logic simulation (ModelSim 6.5B) and timing (post-synthesis) simulation (Quartus II - 9.1). But, when I run the timing simulation in ModelSim (based on the vho+sdo files generated in Quartus) the functionality is incorrect: The first data sample which is written to the FIFO never appears on the FIFO's output lines. All the following data samples appear correctly. Each time I raise the write enable, only the second data sample can be read. Attached:- A logic simulation in ModelSim (perfect functionality) screen shot.
- A timing simulation in ModelSim (incorrect functionality) screen shot.
- Assigning register on for the input and output ports of the DCFIFO to make sure no setup\hold time violations occur.
- Reading from the FIFO a single clock cycle after fifo_empty goes low.
