CycloneV DDR3 Hard Controller: Many Failing Timing Paths
5CSEMA5F31I7N
Hard controller implemented in Platform Designer (PD)
Rest of design passes timing
I've read through the EMI.pdf (External Memory Interface Handbook)
It looks like the PD generated sdc files are in the .qip, and this is included in the project settings files
All of the failing paths are internal to the logic included with the hard controller.
Memory clock: 400MHz (max), Device speed grade is 7 (this is fastest industrial temp)
Is this combination not possible? Is this listed somewhere?
Any suggestions on how to resolve this is appreciated.
- JPB3RD
This issue is resolved. Just to close this out in case it helps someone else, changing the input clock to the DDR3 controller from 200MHz to 100MHz caused all the timing paths to pass (!?). Strangest thing and I'm moving on :-).
- yoichiK_altera
Contributor
Hi
Per EMIF spec estimator speed grad of 7 support 400Mhz of DDR3. Which path is failing ? Are launch and latch clock are same clock resource ?
- JPB3RD
Thank you for your reply. The issue has been resolved and I posted this.
