16 years agoCycloneII or MAXII with the PFL?
I'm trying to implement a system which consists of a CycloneII,two Cyclone IIIs, CFI flash. I'd like to be able to use the parallel flash loader in the CII to JTAG program the flash, as well as confi...
16 years agoHello,rbugalho
I need to configure my system dynamically,and so I want to use large-capacity flash memory to store all my configuration data,then I can dynamically switch to select the desired configuration.That's why I need the large-capacity CFI flash. I noticed that the PFL megafunction for CIII does not allow the operating mode to be set to "FPGA Configuration", as only "Flash Programming" is available as an option,so I cannot replace the Cyclone II with a Cyclone III I use PCI IP core in Cyclone II,However, each reconfigure force me to restart the computer then the core can work well,This is what I do not want to see,So I do not want to re-configure the Cyclone II. I look for FPGA-Based PFL in a lot of dev_kits,but no available reference designs,They all use MAXII,I donot know why?
