11 years ago
Cyclone V vs Cyclone IV static power
From Quartus compilation I see that:
EP4CE115F29C7 115k LE
typical 98.46 mW
max 130.41 mW
5CEBA5U19C7 77k LE
typical 227.17 mW
max 322.46 mW
But... Cyc V shouldn't be 40% lower static power????
    --- Quote Start ---
    typical 98.46 mW
    max 130.41 mW
    5CEBA5U19C7 77k LE
    typical 227.17 mW
    max 322.46 mW
    --- Quote End ---
    Since you mentioned about Quartus II compilation, I believe you are referring to powerplay power analyzer on these values. Mind share with me on the 40% lower static power? Is it extract from the Altera web? By the way, you can use early power estimator to double check on this by just select the device without enable any logic to see if the 40% lower is refer to intrinsic power consumption without power up.
    Just to clarify if the same design file with the same logic turn on in both EP4CE115F29C7 and 5CEBA5U19C7 during compilation.
    Are you referring EPE spreadsheet?
