13 years agoCyclone V SoC Dev Kit PCIe End Port Example
I am trying to get the Cyclone V SoC Development Kit Board to behave as a PCIe End Port. I want to plug this board into a PCIe 4x slot on a PC motherboard running windows. This Dev Kit Board is reall...
13 years agoSo here is a couple more things I've learned:
- I was able to get the example end port design to meet timing with the "8ES" part number, by setting the routing timing optimization setting to "Maximum" in the more fitter settings window. If you make a new project from scratch, make sure to use the qsys and quartus settings found in Altera's example. These settings optimize for clock speed, which you need if you want to meet the 125 MHz requirement for coreclkout.
- Don't allow your BAR address space to become larger than 28-bits. This caused my PC not to boot, which took me a lot of time and frustration to figure out. Dave pointed this limitation out in an old thread titled "PCIe BAR size limitations in Qsys"
