13 years agoCyclone V SoC AHB BUS
Hi I need an AHB bus outside the hps with qsys. The HPS has an h2f_axi_master and f2h_axi_slave_bridge. The qsys interconnect guide is not helpful :cry:.. some idea where to start? some examp...
13 years ago --- Quote Start --- Hi I need an AHB bus outside the hps with qsys. The HPS has an h2f_axi_master and f2h_axi_slave_bridge. The qsys interconnect guide is not helpful :cry:.. some idea where to start? some examples? or something else ? thanks --- Quote End --- Hi, AHB is not equal with AXI interface. AHB is between HSP-FPGA bridges for example. The signals you mentioned are AXI interface signals. For details see the Cyclone V SoC Handbook: http://www.altera.com/literature/hb/cyclone-v/cyclone5_handbook.pdf For reference design which contains HPS integrated with some FPGA slave peripherals here (called Golden HW/SW reference design - ghrd/gsrd): <altera_installation_directory>\13.0sp1\embedded\examples
This FW design uses LW HPS2FPGA bridge, but easily can be replaced with high-speed HPS2FPGA bridge connected to a BRAM on FPGA side. ZS.V.
