I can only share the IP from altera all other logic and block will be cropped if this is ok for you I will cont'd to do so.
Q: I think the major issue here is reconfiguration block 1 -> top 1->bottom only 1 on each.
so if the reconfiguration block already hold by PCIe there is not way additional transceiver can run on different speed unless it is same as PCIe spec.
So before we spend time on this maybe have a look on Q:
I am not sure you are altera FAE staff or just regulator forum contributor?
However, I think if you have idea have to do it you should able to use this to validate what we are discussing.
Fair enough for my side to provide this and I cannot see why there are no easy test on your side to validate this as well.
Brian
Hi Brian,
Thanks for your update. Sure, let me take a look into your latest Q before we decide on the next step of debugging.
