ZArsl
7 years agoCyclone V Kernel Panic after SDRAM EDAC enable
I have enabled EDAC support for my Cyclone V custom board in the kernel .config (kernel v. 4.14.54)
CONFIG_EDAC=y
# CONFIG_EDAC_LEGACY_SYSFS is not set
CONFIG_EDAC_DEBUG=y
CONFIG_EDAC_ALTERA=y
CONFIG_EDAC_ALTERA_SDRAM=y
CONFIG_EDAC_ALTERA_L2C=y
CONFIG_EDAC_ALTERA_OCRAM=y
CONFIG_EDAC_ALTERA_ETHERNET=y
CONFIG_EDAC_ALTERA_NAND=y
CONFIG_EDAC_ALTERA_DMA=y
CONFIG_EDAC_ALTERA_USB=y
CONFIG_EDAC_ALTERA_QSPI=y
CONFIG_EDAC_ALTERA_SDMMC=yAfter, I did extend my .DTS als following (Although I do not need to that because in "socfpga.dtsi" there is already a similar line. Even without declaring this node explicitly, the same error happens)
sdramedac {
compatible = "altr,sdram-edac";
altr,sdr-syscon = <&sdr>;
interrupts = <0 39 4>;
};If I reboot my System now, I get a Kernel panic every time!
EDAC MC0: Giving out device to module altera_edac controller soc:sdramedac: DEV soc:sdramedac (INTERRUPT)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
Synopsys Designware Multimedia Card Interface Driver
dw_mmc ff704000.dwmmc0: 'num-slots' was deprecated.
dw_mmc ff704000.dwmmc0: IDMAC supports 32-bit address mode.
Kernel panic - not syncing:
EDAC: [12 Uncorrectable errors @ 0x07AF25EC]
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.54 #1
Hardware name: Altera SOCFPGA
[<801131c0>] (unwind_backtrace) from [<8010d5f8>] (show_stack+0x20/0x24)
[<8010d5f8>] (show_stack) from [<8066a23c>] (dump_stack+0x80/0x94)
[<8066a23c>] (dump_stack) from [<801237a0>] (panic+0xec/0x258)
[<801237a0>] (panic) from [<804f89d8>] (altr_sdram_mc_err_handler+0x128/0x138)
[<804f89d8>] (altr_sdram_mc_err_handler) from [<8016f488>] (__handle_irq_event_percpu+0x84/0x2b4)
[<8016f488>] (__handle_irq_event_percpu) from [<8016f6e4>] (handle_irq_event_percpu+0x2c/0x68)
[<8016f6e4>] (handle_irq_event_percpu) from [<8016f768>] (handle_irq_event+0x48/0x6c)
[<8016f768>] (handle_irq_event) from [<80173384>] (handle_fasteoi_irq+0xc8/0x17c)
[<80173384>] (handle_fasteoi_irq) from [<8016e580>] (generic_handle_irq+0x34/0x44)
[<8016e580>] (generic_handle_irq) from [<8016eb94>] (__handle_domain_irq+0x8c/0xfc)
[<8016eb94>] (__handle_domain_irq) from [<80101548>] (gic_handle_irq+0x5c/0xa0)
[<80101548>] (gic_handle_irq) from [<8010e34c>] (__irq_svc+0x6c/0xa8)
Exception stack(0xbe8ddb60 to 0xbe8ddba8)
db60: bd792000 00000000 bd792040 00004448 80975f30 be801e40 60000013 014000c0
db80: 8042b060 be8ddbd8 00004446 be8ddbd4 00000000 be8ddbb0 803b634c 802540e4
dba0: 60000013 ffffffff
[<8010e34c>] (__irq_svc) from [<802540e4>] (__slab_alloc.constprop.9+0x54/0x58)
[<802540e4>] (__slab_alloc.constprop.9) from [<802541e8>] (__kmalloc+0x100/0x280)
[<802541e8>] (__kmalloc) from [<8042b060>] (dma_common_contiguous_remap+0x48/0xc8)
[<8042b060>] (dma_common_contiguous_remap) from [<80119244>] (__alloc_remap_buffer+0x70/0xa8)
[<80119244>] (__alloc_remap_buffer) from [<801192b4>] (remap_allocator_alloc+0x38/0x40)
[<801192b4>] (remap_allocator_alloc) from [<801187c4>] (__dma_alloc+0x17c/0x304)
[<801187c4>] (__dma_alloc) from [<801189e8>] (arm_dma_alloc+0x50/0x58)
[<801189e8>] (arm_dma_alloc) from [<8042aa6c>] (dmam_alloc_coherent+0x9c/0x104)
[<8042aa6c>] (dmam_alloc_coherent) from [<80517e8c>] (dw_mci_probe+0x4ec/0xc5c)
[<80517e8c>] (dw_mci_probe) from [<80519990>] (dw_mci_pltfm_register+0xac/0xb8)
[<80519990>] (dw_mci_pltfm_register) from [<805199fc>] (dw_mci_pltfm_probe+0x3c/0x40)
[<805199fc>] (dw_mci_pltfm_probe) from [<80418e34>] (platform_drv_probe+0x60/0xc0)
[<80418e34>] (platform_drv_probe) from [<80416d80>] (driver_probe_device+0x258/0x2dc)
[<80416d80>] (driver_probe_device) from [<80416ecc>] (__driver_attach+0xc8/0xcc)
[<80416ecc>] (__driver_attach) from [<80414ee8>] (bus_for_each_dev+0x78/0xac)
[<80414ee8>] (bus_for_each_dev) from [<80416680>] (driver_attach+0x2c/0x30)
[<80416680>] (driver_attach) from [<804160bc>] (bus_add_driver+0x114/0x220)
[<804160bc>] (bus_add_driver) from [<80417c28>] (driver_register+0x88/0x104)
[<80417c28>] (driver_register) from [<80418d80>] (__platform_driver_register+0x50/0x58)
[<80418d80>] (__platform_driver_register) from [<80934724>] (dw_mci_pltfm_driver_init+0x24/0x28)
[<80934724>] (dw_mci_pltfm_driver_init) from [<80101c5c>] (do_one_initcall+0x54/0x178)
[<80101c5c>] (do_one_initcall) from [<80900fe4>] (kernel_init_freeable+0x1d0/0x260)
[<80900fe4>] (kernel_init_freeable) from [<8067f1a8>] (kernel_init+0x18/0x120)
[<8067f1a8>] (kernel_init) from [<80108408>] (ret_from_fork+0x14/0x2c)
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.14.54 #1
[<8066a23c>] (dump_stack) from [<80110598>] (handle_IPI+0x378/0x3e8)
[<80110598>] (handle_IPI) from [<80101588>] (gic_handle_irq+0x9c/0xa0)
[<80101588>] (gic_handle_irq) from [<8010e34c>] (__irq_svc+0x6c/0xa8)
Exception stack(0xbe905f38 to 0xbe905f80)
5f20: 00000001 807b5218
5f40: 3f66a000 8011c720 be904000 80a03d34 80a03ce8 80a5c217 807b8760 413fc090
5f60: 00000000 be905f94 be905f98 be905f88 801095b4 801095b8 60070013 ffffffff
[<8010e34c>] (__irq_svc) from [<801095b8>] (arch_cpu_idle+0x48/0x4c)
[<801095b8>] (arch_cpu_idle) from [<80684b3c>] (default_idle_call+0x30/0x3c)
[<80684b3c>] (default_idle_call) from [<80161830>] (do_idle+0xd4/0x144)
[<80161830>] (do_idle) from [<80161b7c>] (cpu_startup_entry+0x28/0x2c)
[<80161b7c>] (cpu_startup_entry) from [<8010ffb4>] (secondary_start_kernel+0x164/0x16c)
[<8010ffb4>] (secondary_start_kernel) from [<001019ec>] (0x1019ec)
---[ end Kernel panic - not syncing:
EDAC: [12 Uncorrectable errors @ 0x07AF25EC]In the preloader the ECC gets enabled succesfully:
U-Boot SPL 2013.01.01 (May 13 2019 - 09:02:26)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 50000 KHz
CLOCK: EOSC2 clock 50000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 3125 KHz
RESET: COLD
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
SDRAM: ECC Enabled
ALTERA DWMMC: 0What am I missing?
- FawazJ_Altera
I would like to know if the issue still persisting.
Thank you
- FawazJ_Altera
Is this a custom board or development kit?
If you keep EDAC disabled, are you able to boot the linux?
