hsyn
3 years agoCYCLONE V HPS SDRAM - Enable with Hardware Diagnostic Option in bsp-editor
Hello, I want to perform a DDR RAM test with u-boot for my PCB that has a CYCLONE V. My PCB has 256MiB memory. When I select HARDWARE_DIAGNOSTIC in bsp-editor.exe for this purpose, I receive a warn...
aikeu
3 years agoHi ieeeHuseyin,
I do not fully understand the test algorithment yet. Anyway the cnt = cnt++ seems like not right to me as well. The process of writing data_temp(Rotate_Right) should be the same as the process to compared with expected_data(Rotate_Right).
If you can oberve the same writen memory status pattern as shown in the expected example results in the document then I think it should be correct.
Aik Eu
