Cyclone V GPI Maximum Input limit - 5CSEBA4U23I7N
Hi
We are using the GPI pins in the Cyclone V processor. Our DDR voltage is 1.35V. What is the maximum input voltage these pins can tolerate? pins are listed below.
In our design we have connected 3V3 pull up to this line.
HPS_GPI13 - V24
HPS_GPI12 - AC27
HPS_GPI9 - Y26
HPS_GPI6 - T17
Hi Binoy
From the De1-SOC-Schematics you can see, that all banks have vcio=3.3V
vcio=3.3v (except the HPS-banks which use 1.5V
1.5v). Pins on these banks will correctly detect 2.5V CMOS input , but they will not be able to generate 2.5V output.
Thank you,
Aliff
- mabdrahi
Contributor
Hi Binoy,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Aliff
- mabdrahi
Contributor
Hi Binoy,
The maximum voltage also will follow the VDD as well
For full document you can refer to https://cdrdv2-public.intel.com/654351/pcg-01014.pdf page, 25-30
Let me know if i answer your question
Thank you,
Aliff
- Binoyjohnson
Thanks for the clarification
- Binoyjohnson
Thanks for clearing the doubt.
We had a confusion regarding the following pins.
HPS_GPI13 - V24
HPS_GPI12 - AC27
HPS_GPI9 - Y26
HPS_GPI6 - T17
Since these pins are belongs to BANK 6B and our 6B bank voltage is connected to VDDR = 1.35V.
If you can mention the datasheet location it would be great.
Thanks Regards
Binoy Johnson
- mabdrahi
Contributor
Hi Binoy
After checking this datasheet https://cdrdv2-public.intel.com/666692/cv_51002-683801-666692.pdf the Max voltage the pin can tolerate was 3.465v
Thank you,
Aliff
- mabdrahi
Contributor
Hi Binoy
Thank you,
Aliff
- mabdrahi
Contributor
Hi Binoy,
I will check the information about the listed pin and what is the maximum input voltage these pins can tolerate.
I will back soon
Thank you,
Aliff
- Binoyjohnson
Thanks for the Update. You are right, I am expecting the same answer. What is the maximum voltage these pins can tolerate?
