Binoyjohnson
3 years agoCyclone V GPI Maximum Input limit - 5CSEBA4U23I7N
Hi We are using the GPI pins in the Cyclone V processor. Our DDR voltage is 1.35V. What is the maximum input voltage these pins can tolerate? pins are listed below. In our design we have connected...
- 3 years ago
Hi Binoy
From the De1-SOC-Schematics you can see, that all banks have vcio=3.3V
vcio=3.3v (except the HPS-banks which use 1.5V
1.5v). Pins on these banks will correctly detect 2.5V CMOS input , but they will not be able to generate 2.5V output.
Thank you,
Aliff
mabdrahi
Contributor
3 years agoHi Binoy
After checking this datasheet https://cdrdv2-public.intel.com/666692/cv_51002-683801-666692.pdf the Max voltage the pin can tolerate was 3.465v
Thank you,
Aliff
