Binoyjohnson
3 years agoCyclone V GPI Maximum Input limit - 5CSEBA4U23I7N
Hi We are using the GPI pins in the Cyclone V processor. Our DDR voltage is 1.35V. What is the maximum input voltage these pins can tolerate? pins are listed below. In our design we have connected...
- 3 years ago
Hi Binoy
From the De1-SOC-Schematics you can see, that all banks have vcio=3.3V
vcio=3.3v (except the HPS-banks which use 1.5V
1.5v). Pins on these banks will correctly detect 2.5V CMOS input , but they will not be able to generate 2.5V output.
Thank you,
Aliff
mabdrahi
Contributor
3 years agoHi Binoy,
I will check the information about the listed pin and what is the maximum input voltage these pins can tolerate.
I will back soon
Thank you,
Aliff
- Binoyjohnson3 years ago
Thanks for the Update. You are right, I am expecting the same answer. What is the maximum voltage these pins can tolerate?
