Bill_A's avatar
Bill_A
4 years ago
Cyclone V E AS Configuration with MX25L256
Trying to configure a Cyclone V 5CEFA2U19I7 with an MX25L256 fails. The device is MX25L25645GZ2I-08G. It is configured to use Active Serial x4. Here is more information.
  • Programming .SOF through JTAG works fine.
  • We can create and program the MX25L256 with a .JIC file.
  • The Examine reads back the same data that is programmed with the JIC.
  • We have tried Active Serial x1 and Active Serial X4.
  • We have tried AS Fast and AS Standard.
  • We have tried Quartus Lite 20.1.1.720 and 21.1.0.842.
  • We have tried the Internal Oscillator at 100 MHz and at 12.5MHz.
The behavior is the same. After power on, the FPGA reads the SPI FLASH. After the read is complete, the DCLK changes to the configuration clock frequency. Before configuration completes, nSTATUS goes low and the FPGA re-starts configuration. All power rails look good.
  • Farabi_Altera's avatar
    Farabi_Altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    regards,
    Farabi
    Farabi_Altera
    I am Farabi who will support your configuration issue.
    The nSTATUS goes low during configuration means some setting is not set the correct way.
    May I know how you connect the MSEL pins? are they connected to some other controller IOs or are they connected to a fixed connection like pull high/pull low (by switches)?
    regards,
    Farabi
    • Bill_A's avatar
      Bill_A
      The MSEL pins are connected through zero Ohm resistors. We have tried AS Standard (R370 out and R367 in) and AS Fast(R370 in and R367 out) . I have attached a picture.
      • Bill_A's avatar
        Bill_A
        Do you need a copy of the .JIC file? We have created one with all combinations of the Advanced options and all behave the same.
        Disable EPCS/EPCQ ID check
        Disable AS mode CONF_DONE error check.
      Farabi_Altera
      Do you have any updates? Or you can private email me the schematic of configuration connection page.
      regards,
      Farabi
