Cyclone V E AS Configuration with MX25L256
I am Farabi who will support your configuration issue.
The nSTATUS goes low during configuration means some setting is not set the correct way.
May I know how you connect the MSEL pins? are they connected to some other controller IOs or are they connected to a fixed connection like pull high/pull low (by switches)?
regards,
Farabi
- Bill_A4 years ago
The MSEL pins are connected through zero Ohm resistors. We have tried AS Standard (R370 out and R367 in) and AS Fast(R370 in and R367 out) . I have attached a picture.
- Bill_A4 years ago
Do you need a copy of the .JIC file? We have created one with all combinations of the Advanced options and all behave the same.
Disable EPCS/EPCQ ID check
Disable AS mode CONF_DONE error check.
- Bill_A4 years ago
I have attached a picture with the connections to the SPI FLASH
- Farabi_Altera4 years ago
Do you have any updates? Or you can private email me the schematic of configuration connection page.
regards,
Farabi
