comccmoc
3 years agoCyclone V dedicated flash pins with generic serial flash interface
I am getting "Illegal constraint of I/O pad" errors when attempting to connect a GSFI IP to top level I/O corresponding to the NCSO, DCLK, and DATA[3..0] pins, even though I have it set in the GSFI I...
FvM
3 years agoHave you set these pins to "use as regular IO" in the device and pin options, tab dual purpose pins?
- comccmoc3 years ago
Unfortunately, the only things I have listed in that window are Data[15..8] and Data[7..5]. Both are already listed to be used as regular I/O.
