Cyclone V configuration bank I/O voltage
I am sorry you still have the same problem after 7 years. May I know what error did you receive when that box is checked?
Force VCCIO voltage to be compatible with configuration I/O voltage—Forces the VCCIO voltage of the configuration pins to be the same as the configuration device I/O voltage. If you turn off this option, the VCCIO voltage of the configuration pins may vary depending on the I/O standards used in the I/O banks containing the configuration pins. This option is available for supported device families.
Thank you.
- EdJ5 years ago
Sorry, it was somebody else that asked the question 7 years ago. I located it when I searched the forum before I posted. The reason for the option in Quartus to force I/O voltages in the bank to be consistent with VCCPGM was not made clear in the responses to that question. That question as well as mine referred to the Cyclone V series. After posting I realized that other chips supported by Quartus may require that the I/O in the config bank must have the same voltage as the programming voltage, so that is why the box option is there.
While I have your attention, could you confirm that my scheme and voltage choices (JTAG voltage, JTAG pull-up voltage, config pin pull-up voltage, I/O bank 3A voltage) described in my 1st post are correct for ASx4, with config device programming via the Serial Flash Loader? Thanks a lot.
Ed- AminT_Intel5 years ago
I think your scheme and voltage choice looks good so far. You can refer to Pin Connection Guidelines for more details on power supply: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
Thank you.
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
