10 years agoCyclone V and Gate Level Simulation
Quartus won't run a gate level simulation when using the Cyclone V family.
Is it possible to run gate level simulation with the Cyclone V devices? For other devices, Quartus generates simulation files: up_counter.vo up_counter_6_1200mv_0c_slow.vo up_counter_6_1200mv_85c_slow.vo up_counter_min_1200mv_0c_fast.vo But with the Cyclone V family it is only generating: up_counter.vo8 Replies
Static timing analysis alone does not allow for comprehensive verification. Among the issues
- STA cannot identify asynchronous interfaces - The error prone selection of false paths - Constraint requirements for multi-cycle paths - Common concurrence point along implementation flow to a known good test bench is lost. - Altera_Forum
You are right. Also the CV should be of the low cost FPGA series.
I'd bet that Altera decided that Timequest was more accurate than gate level simulation so there was no reason to support both methods.
you are right, think it is a way to save $$.
Reason is money, models for gate level simulation are $$$ and 28nm design is already $$$
--- Quote Start --- Cyclone V = no gate level simulation Rely on TimeQuest --- Quote End --- Good info sharing. Dint aware of it till now. - Altera_Forum
--- Quote Start --- Cyclone V = no gate level simulation Rely on TimeQuest --- Quote End --- Thanks. Is there a reason that gate level is not supported? - Altera_Forum
Rely on TimeQuest
