StefanoMarsi's avatar
StefanoMarsi
3 years ago
CYCLONE V - HPS and I2C Peripheral Pin
Hi Community
I'm testing the I2C interface embedded in CycloneV - HPS.
- However, if I export peripherals signals through the HPS I/O Set everything works pretty well.
- But If I switch to FPGA: exporting signals to FPGA Fabric (integarting them with suitable I/O Tristate buffers) the I2C protocol is completely different, the frequency of I2C signals passes from 100kHx to 6 kHz, and even if SDA seems in a certain way coherent with data, SCL is not.
Please note the different behavior in the images attached.
Any help will be appreciated!
  • StefanoMarsi's avatar
    StefanoMarsi
    don't worry
    In the meantime, I've done some other tests and I've to admit that it is a mess:
    In particular, I've tried to drive both peripheral i2c0 and i2c1 to FPGA in the same exact way and their behavior is totally different:
    - i2c1 presents the malfunctioning I mentioned in the previous posts (wrong frequency and duty cycle) when drived to FPGA but it works properly when driven to the devoted pins.
    - i2c0 presents a correct frequency and the data shape is OK but it completely ignores the ACK received from the device, (even if present)
    ad it limits the entire communication to send the first byte (i.e. the address of the device) then it releases the bus and does not send anything else.
    I2c2 and i2c3 is not available via software without a suitable preload.
    Is it possible that the problem is in the preload?
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Sorry for the late response.
    I still got no further update from engineering at this moment on the next step of action.
    Jingyang, Teh
    StefanoMarsi
    However, looking in detail at the previous images there is another slight difference:
    - When the HPS pins are used, the output port of the I2C peripherals is named I2C_CLK_OE and I2C_DATA_OE
    - While when I try to drive them to the FPGA pins they are named OUT_CLK and OUT_DATA
    It seems quite strange the adoption of different port names ! (may be different signals are involved !?)
    StefanoMarsi
    Thank you for your kind answer, but unfortunately, the result is the same !
    Please note that the i2C waveforms present a certain coherence but the frequency and the duty cycle are completely wrong.
    Moreover looking at the RTL representation the main difference is that using the HPS pins there are no input buffers (is it possible?) for the signal and the buffers are located quite near the I2C peripheral, while if I try to drive the pins to the FPGA fabric an input buffer is added and all the buffers are located in the I/O resources.
    I included a couple of images to better explain this difference.
    Thank you for your support
    tehjingy_Altera
    Hi
    I have filed a ticket to engineering.
    Will update here if there are any update.
    Thanks for sharing your project with us.
    Jingyang, Teh
    StefanoMarsi
    Thank you for your help
    - I'm using Quartus 22.1 std
    - with intel monitor program 21.1
    - The board is a De1-SOC (Teraic) rev. G P.N. 10-01306101-G0
    attached the .qar file of the project.
    Thank you
    tehjingy_Altera
    Hi
    Sorry for the late reply. I was OOO last week.
    After talking with a senior colleague, this could be a bug from our end.
    I will file a ticket to get engineering help.
    Could you provide additional below:
    Quartus Version you are using?
    Is this a devkit or a custom board? If it is a devkit could you provide the part number?
    Could you also share with us the project file that you are working on?
    Jingyang, Teh
    tehjingy_Altera
    Hi Stefano
    From the waveform that you shared, we could see that the signals are distorted when it is routed through the FPGA.
    Have you tried not passing the i2c signals through the tri-state buffer?
    Could you also try setting the I/O standard to Open Drain as suggested in the CycloneV interface guideline?
    Please refer to this link on the i2c guidline placement.
    https://www.intel.com/content/www/us/en/docs/programmable/683360/18-0/i2c-interface-design-guidelines.html
    Jingyang, Teh
      StefanoMarsi
      This is exactly what I did!
      Please note the implementation in the attached code!
