14 years agoCyclone IV GX Transceiver Starter Board
hi I have a question about this board. I want to kown which pin is the clock pin? In the Cyclone IV GX Transceiver Starter Board Reference Manual, I just find three differental clocks. When I ...
14 years ago --- Quote Start --- Everything is OK with differential clock. Declare Your clock input as LVDS signal and assign both signals to corresponding FPGA pins. --- Quote End --- Thank you for you help. My problem has been solved.:)
