8 years ago
Cyclone IV E, transferring data using serial port
Hello everyone,
In a nutshell I have the following FPGA: http://fpga.redliquid.pl/images/ep4ce6/1.jpg
(FPGA Cyclone IV E, ECP4E6), and what I want to do is to use the serial port.
I've been following the following tutorial:
https://www.youtube.com/watch?v=7xj9dhvdcwu
(My quartus 2 is version 17.1).
As far as I know this tutorial should be adapted for my specific board. I'm quite new to FPGA, so I might get confused a bit. At 3:40 is where I get confused, it is my understanding I need to map the I/O of the UART module created using that procedure to the I/O of the RS232 on the board.
I don't actually know what the correspondings pins are, and also I can't manage to find anything in the documentation, but I think it's me reading something in the wrong way.
Can anyone help me with this? I'm sure it is a "silly" thing to do.
(of course if you know a simpler procedure please share).
My final goal would be practice a bit with serial port and later developing some arithmetic units and passing data using my pc.
https://alteraforum.com/forum/attachment.php?attachmentid=15101&stc=1 Thank you
    It does have an SDRAM. Just a silly question,once I create the HDL using the platform planner (I managed at last) before compiling how do I get the name of the entity to be used as top entity?
    Go through some basic training.
    https://www.altera.com/support/training/curricula.html
    Refer following Links.
    https://www.youtube.com/watch?v=nhfvwthr_ew
    https://www.youtube.com/watch?v=yetvltb4hm4
    First, understand you board specification.
    Do you have onboard SDRAM, You can use on-chip ram instead of using SDRAM to avoid extra pin assignment work.
    To eliminate the error.
    Auto-assign the base address and interrupt from a system option from tools bar of qsys.
    Anand Raj Shankar
    Hi again,
    Can you explain or give a reference why I need to istantiate the Nios II and the SDRAM block? (I get of course why I need the UART bit). Is it because I need later to create the C program that process the inputs?
    --- Quote Start ---
    Yes, you can use.
    Google and search for some reference design and how to install Hyperterminal on windows 10.
    Anand Raj Shankar
    --- Quote End ---
    I'm not concerned about hyperterminal but for the rest of the procedure.
    I'll give it a go and let you know.
    Yes, you can use.
    Anand Raj Shankar
    Is that tutorial adaptable for my board + windows 10 + quartus 17.1?
    Your board does not have a USB interface/connector.
    You can use Hyperterminal and a serial port(RS232) on your board and establish the serial communication.
    Use Nios ii processor, on-chip memory, jtag Uart & uart(rs232 serial port) for qsys design.
    For more information refer to link below.
    http://my-fpga.blogspot.my/2011/02/using-rs232-on-niosii-processor.html
    Anand Raj Shankar
    • MRP's avatar
      MRP
      Dear Anand Raj Shankar
      I am using CoreEP4CE6, Altera Core Board for my lab work. I am also trying to communicate with MATLAB through UART. So for configuration, can I use the same procedure shown in the following link http://my-fpga.blogspot.my/2011/02/using-rs232-on-niosii-processor.html .
      I am very new to FPGA hardware and my background also does not match with electronics. Help me to configure my FPGA to communicate with MATLAB via UART.
      Best regrads
      MRP
