10 years ago
Cyclone IV configuration - nCONFIG signal and JTAG programming issue
I have a custom board for EP4CE22E22 Cyclone IV FPGA. I have configured the board for JTAG only mode and using USB Blaster Rev.B for programming. The problem I am facing is that JTAG Scan fails with "JTAG chain Broken" error. The signal levels are are follows:
AT POWER UP:
nSTATUS -> HIGH (A0 on attached figure)
nCONFIG -> LOW (Screen shot from logic analyzer shows that nConfig (A1 on figure) goes low after 4ms but this duration is random and sometimes it stays high for several ms)
TCK -> LOW
TDI -> HIGH
TMS -> HIGH
TDO -> LOW
nCE -> LOW
DURING JTAG SCAN:
nSTATUS -> HIGH
nCONFIG -> LOW
TCK -> Square wave with varying duty cycle
TDI -> Toggle few times (Some Bit stream)
TMS -> Toggles few times (Some Bit stream)
TDO -> LOW
Voltage Levels / Connections):
VCCINT: 1.2V
VCCIO : 3.3V (All VCCIOs)
VCCA : 2.5V
E-PAD : GND
JTAG Connector -PIN 4: 3.3V
nCONFIG : Pulled high by a 10K resistor (VCCIO)
nSTATUS : Pulled high by 10k resistor (VCCIO)
TCK : Pulled low by 1K
TDI : Pulled high by 10K (VCCA)
TMS: Pulled high by 10K (VCCA)
TDO : NO pull-up / down
nCE: GND
MSEL[2:0] : GND
According to Cyclone IV handbook the nCONFIG is an input pin but it looks like FPGA is driving it low after power ON, Why is that? Any ideas why JTAG chain scan failing on my board?
    The rev B cable was updated to rev C to overcome this issue. The change was to move to a flex-rigid cable - the electronics in the USB-Blaster are unchanged.
    So, you can get yourself a rev C cable and you'll be away. Alternatively, I suggest you shorten the ribbon cable on your rev B and you'll be happier, since won't have forked out for a new cable. I have several rev B cables all working happily with the new parts. See attached pic. Note - you don't need to go nearly as short as this!
    Cheers,
    Alex
    --- Quote Start ---
    Cheers,
    Alex
    --- Quote End ---
    Thanks Alex, We have sort out the issue. Apparently there was a dry solder connection on the PCB and after applying some hot air on FPGA pins the problem disappeared :).
    now The board works fine with "SOF" files but the FPGA won't reconfigure after power cycle. I have both JTAG and AS mode connectors on the board and tried both POF and JIC files to program the EPCS64 chip. The quartus programmer shows 100% success but reconfiguration doesn't happen after power cycle.
    After some try and error, I noticed that if I left the JTAG cable connected to the AS header of the board (and connect the USB end to PC) the FPGA reconfigures successfully upon power up. I wonder if there is a Licence issue of some kind , even though my code is a simple counter program in verilog without any IP cores from Altera?
    No it can't be a license problem. If you had some Opencores IP it would only work when uploading the .sof file using the programmer and you wouldn't be allowed to flash the design into the EPCS.
    I would rather look for some earthing/grounding problems. When you connect the USB blaster to your board and the PC, you connect your board's ground plane to earth.
    Another possibility is load on the JTAG pins or the VCC power plane connected to the JTAG connector. Do you have pull-up/pulldown resistors on the FPGA's JTAG pins? It's not required but depending on your PCB design they could pick up noise during startup that would disturb the start-up process.
