ericmtzr
4 years agoCyclone IV AS Thermal Issue
One of my clients has problems with the temperature of a Cyclone IV FPGA (AS configuration for the Cyclone IV GX), I attach a document with information, could you please help me.
Regards.
- Ash_R_Altera
Hi Eric,
Is there any update from customer?
- ericmtzr
I already sent the comments to my client, as soon as I have an answer, I'll let you know.
Regards.
- Ash_R_Altera
I am suspecting that probably there is some loading happening on the board. Can you try these experiments in sequence on your original circuit (without resistor that you manually added) and check the results?
1) Remove the capacitor C220 and check at all the temp range.
2) Along with 1), remove the LED as well and check across all temp ranges.
