16 years agoCyclone III
Hi, I am starter to cyclone III, I tried to connect the power and ethernet cable. It tries to connect to the network, but failed and defaults to static IP address. I had tried to installed the...
16 years agoSpecific versions of tools and dev kits that you're using might help...
Some network switches are set to disallow DHCP from clients that send certain "initial" IP Addresses...like 192.168.x.x, for example. Take a look at the software to see what initial IP address is being sent to rule that issue out. Cheers, -slacker
