16 years agoCyclone III
Hi, I am starter to cyclone III, I tried to connect the power and ethernet cable. It tries to connect to the network, but failed and defaults to static IP address. I had tried to installed the...
16 years agoBy default, if the IP address is configured to 192.168.0.50. If static IP addressing is used, you must configure your computer to an IP address in the subnet as the cable to communicate with it. The default setting requires your address to be in the 192.168.0.X network domain. Kindly check on the setting for that.
You may also refer to your operating system manual or contact your network administrator to verify that your network supports DHCP services.
