16 years agoCyclone III PLL cascading - lack of information
Hi everyone! I try to run a Design with two PLLs. The first one not reconfigurable, inclk from dedicated clock pin (100MHz), located in PLL1. The second one is reconfigurable, inclk from the first...
16 years agoHi Carsten,
I don't get it. When I unfold "category", I see PLL, amongst others (see picture). Did you already assign a device? Because if no device is assigned, the location could not be determined. Regards, Ton
