16 years agoCyclone III PLL cascading - lack of information
Hi everyone! I try to run a Design with two PLLs. The first one not reconfigurable, inclk from dedicated clock pin (100MHz), located in PLL1. The second one is reconfigurable, inclk from the first...
16 years agoHi Ton, thank you for the hint. But I can't find the option "PLL" in Category in Quartus 9.1 SP2. Do you have an idea? I can see a similar option called "Locations" but it isn't possible to select a PLL. Du you have an idea?
BR, Carsten
