16 years agoCyclone III PLL cascading - lack of information
Hi everyone! I try to run a Design with two PLLs. The first one not reconfigurable, inclk from dedicated clock pin (100MHz), located in PLL1. The second one is reconfigurable, inclk from the first...
16 years ago --- Quote Start --- How is it possible to select a PLL? (Changing from PLL2 to PLL3) --- Quote End --- Open the assignment editor in Quartus II by right clicking the PLL and select Locate in assignment editor. In category: select PLL In the lower part you can select the Loaction. (see attached jpg-file) Good luck, Ton
