16 years agoCyclone III package question about EQFP144
I noticed that the EQFP144 package has an exposed pad on the bottom. I did not account for this in my board layout. How big of a problem is this?
16 years agoYes, I know, low inductance and high current capability are the same thing when dealing with high frequencies, and my next preproduction run will have a ground pad connected to the ground plane on one of the inside layers by 8 vias.
For now I just want to power up the FPGA so I can discover whether there are any other problems with the design that need immediate fixing before the next revision. Problem is I have the 1.2V rail on a polygon right under the chip so fetching ground will either have to go by a wire to the back or out one of the corners.
