16 years agoCyclone III I/O standard
Hi there, in the device family datasheet I read that the Cyclone III device supports LVTTL & LVCMOS. In order to interface the device with standard TTL circuits I think I need some kind of buffer...
16 years agoTo be on the safe side, indeed use a level-shifter.
But there is an alternative. Check the chapter "5.0-V Device compatibility" in the CII device handbook. This chapter dissapeared in the CIII device handbook (why?), but the theory is still applicable. But be carefull, only apply the higher voltage after the device is configured, because the clamping diodes are activated during configuration. Cheers, Ton This suggestion is given without warranty
