16 years agoCyclone III Initialization issue
I am using Cyclone III [EP3C16] on my custom built board. I programmed the device with a simple .sof file using Quartus II 9.0sp2 Web Edition via USB Blaster. I see the CONF_DONE pin high after configuring and the Quartus say success. But the FPGA didn't work:( The INIT_DONE pin is also not returning to High [have made software configuration for using the INIT_DONE pin]. I have made sure the following 1) Proper power supply 2) Proper External Clock to the FPGA 3) Have made the JTAG connections [support for both JTAG and Active serial] as per the Altera's suggestions 4) I was not sure whether JTAG module needs to be supplied with 3.3V or 2.5V. I tried both, but still the same issue. 5) nStatus and nConfig pins High When I use SignalTap, it is able to download the .sof, CONF_DONE goes High. But when I try to Analyse [RunAnalyse/AutoAnalyse], SignalTap says "JTAG Communication Error" and also says "instance not found". I understand that the FPGA is getting configured but not initialized. What am I missing here? What should I do to make the FPGA work? I request you people to help me getting out of this issue. Please let me know if you need any further details to find out this issue. Regards, Jaga1 Reply
Sounds like the FPGA looses it's configuration. One possible reason is either in NCONFIG driven low or a conflicting action of the on-chip configuration controller. The latter can happen, if e.g. an unconfigured AS device is connected to the FPGA. There's a Quartus programmer option to halt the on-chip configuration controller. Another possible reason is momentary drop of a power supply below the POR threshold.
